08-04-2017 11:41
08-04-2017 11:41
After charging my Fitbit Blaze, the screen does not display anything other than the battery status.
I have reset the device using the home and bottom right buttons and the Fitbit logo displays and then goes away and nothing display other than the battery status in the upper left of the screen.
Best Answer08-05-2017 07:35
08-05-2017 07:35
@okjtj, when you put your blaze on the charger you will see your battery status, it will show it charging or show full charge. If you tap on the screen you should be able to see the clock. If this is not happening I would contact customer support.
Best Answer08-05-2017 13:30
08-05-2017 13:30
Welcome to the forums!
Here is how to contact support
Look around the forums and join in on some of the discussions! Lot's going on!
Hope to see you around!
Wendy | CA | Moto G6 Android
