Got battery low notification. Put blaze in charger. Battery icon on blaze shows 4 bars. One hour later battery icon on blaze shows 4 bars. Remove blaze from charger. Restart blaze. Put blaze in charger. Battery icon on blaze shows 9 bars.
Best AnswerTook it out to walk around and Sync. Now the app shows green for the battery charge. Put blaze back in charger only 2 red bars. WTH is going on with this thing? Why is the battery charge level on the blaze not showing the right level?
@aspexil wrote:Took it out to walk around and Sync. Now the app shows green for the battery charge. Put blaze back in charger only 2 red bars. WTH is going on with this thing? Why is the battery charge level on the blaze not showing the right level?
The app will only show the battery level durring the last sync.
When you place the Blaze in its charger, or swipe off the clock you will see the battery level that the Blaze is at.
The battery level on the Blaze is showing the tight level, It is the app that is sjowing the level the battery was at during the last successful sync.
As you noticed
Sync again now says battery empty. This is insane.
This is the way Fitbit works.
A sync sends the Battery level to the Fitbit server.
The app gets its data from the same server, not directly from the Blaze
