11-21-2017 17:18
11-21-2017 17:18
I just bought the Blaze & it will not hold a charge for longer than 2 days. I bought one for my mom for Xmas too... I'm wondering if this is a bigger issue. I've only had it 2 wks.
Best Answer11-21-2017 18:10
11-21-2017 18:10
My Blaze is 1.5 years old and now I have that problem as well. I talked to customer service and they were no help. I would return it and purchase another product.
Best Answer11-22-2017 07:43
11-22-2017 07:43
Hey there @Stacie0302, it's great to welcome you and @drussell to see you around.
If your tracker isn't holding a charge, I recommend taking a look at this post and follow the instructions provided there.
I hope this helps, let me know the outcome. ![]()
Best Answer11-22-2017 10:33
11-22-2017 10:33
Best Answer11-22-2017 15:16
11-22-2017 15:16
Thank you @AlejandraFitbit! I've made some changes to my settings & I'll wait to see what happens. I'm sure it's not dirty as it's brand new. I also just purchased one for my Mom so fingers are crossed this will work!
12-07-2017 19:38
12-07-2017 19:38
Blaze not holding charge
Best Answer12-08-2017 07:23
12-08-2017 07:23
Thanks for the information @Stacie0302, @drussell and @Walston21 great to see you here.
@drussell, since the troubleshoot provided didn't work, I recommend keeping an eye on your inbox for further assistance. @Stacie0302, I would like to know if the instructions provided worked for you, did you notice any different in the Blaze battery life? And @Walston21, have you checked my previous post and follow the steps there? If you haven't, please do.
Hope to hear from you soon. ![]()
