07-24-2018
09:41
04:56
AlejandraFitbit
07-24-2018
09:41
04:56
AlejandraFitbit
My Blaze is less than a year old and is only holding a charge for about 5 hours. Is there any way to fix this? it used to last up to 5 days!
04:57
08:06
07-25-2018
04:57
08:06
A warm welcome to the Community @ShamrockRN.
If you are having issues with your tracker holding a charge, I recommend taking a look at this post and follow the instructions provide there.
I hope this helps, let me know the outcome. ![]()
Best Answer07-25-2018 05:32
07-25-2018 05:32
Thanks @AlejandraFitbit, I actually had tried troubleshooting.....but that was not the cause. I contacted customer support and they reviewed my charging/battery life logs and are replacing the Fitbit as it is still under warranty! Thanks again!!
07-26-2018
04:02
08:06
07-26-2018
04:02
08:06
Those are great news @ShamrockRN, I am glad to hear that you will be receiving a new unit. At the moment of receiving, you just need to do the following from your Fitbit app to set it up:
Keep the stepping up! ![]()
