02-27-2016 18:50
02-27-2016 18:50
My Blaze does vibrate when I get a notification but it doesn't light up. Shouldn't it do that?
Best Answer04-12-2016 14:41
04-12-2016 14:41
The difference is that the screen may turn on and the user is not in position to read, or maybe even doesn't need to read the message at this time.
05-07-2016 20:44
05-07-2016 20:44
05-07-2016 22:01
05-07-2016 22:01
The Surge does not light up every time it receives a notifacation, it lights up upon lifting the atm and activation the quick view. As for the unlit display, this is always on.
The Blaze is always off until the display is activated by quick view, a tap, or a push of the button. When a notifavation comes in, the unit buzzes, then lift the arm to activate quick view.
Fitbits thinking i assume is why tuen the display on until the user wants to read the message.
If the display was turned on right away, and the user didn't look at it, then the week be multiple steps lift arm, scroll up with finger, scroll to see message., needed to read the display.
05-08-2016 06:00
05-08-2016 06:00
Best Answer05-08-2016 07:04
05-08-2016 07:04
05-10-2016 07:22
05-10-2016 07:22
Best Answer05-17-2016 06:25
05-17-2016 06:25
Marathon Racer, sorry for the delay in responding, I just saw this. You're absolutely right. The Surge's screen is visible all the time, but it does light up when receiving notifications if the room is dark.
Have a great day!
Bob
Best Answer05-18-2016 08:11
05-18-2016 08:11
Best Answer05-20-2016 09:16 - edited 05-20-2016 09:24
There is nothing to remedy, the screen on the display works the way the developers designed it too.
W hen receiving a message on the Surge, it is displayed immediately, I forget about the backlight. It works like this because the Surge uses an LCD and therefore the display can be kept on.
The Blaze does not have a backlight since it uses LED's, which tend to pull more power from the batteries. When the Blaze received a message, it will inform the user through vibration. There is no reason to turn the display on until the user wants to read the message, therefore the display stays off until the arm is raised, or the Blaze is tapped . This is by design.
There are many times that I received a message, but have no intentions of reading it now. The message states in the to be viewed buffer, so 10 minutes later, I raise my arm and the message pops up.
If the screen lit up when the message came in, it would be cleared from the buffer. Ten minutes later, I still would have to lift my arm, no the second arm would be needed to swipe the screen.
@SpidermanBob, the option to have notifacations light up the Blaze has already been suggested in the feature board. Do a search then vote. The ability to change the on time I don't think has been suggested, you could add this to the features board. Then post a link here, I think it is a great idea and will be glad to come on it.
05-20-2016 11:22
05-20-2016 11:22
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
11-04-2016 05:22
11-04-2016 05:22
For me it's not working. I tried to paralell the device with my body and twist the wrist and is not working.
Best Answer11-06-2016 15:50
11-06-2016 15:50
When I raise my arm my Fitbit Blaze shows me the time. This is until today. All of a sudden, I have to press the button to see the screen. Not sure what changed.
Best Answer11-06-2016 15:52
11-06-2016 15:52
01-09-2017 13:19
01-09-2017 13:19
Yippee!! That solved everything!
01-10-2017
07:09
06:50
01-10-2017
07:09
06:50
Welcome to the Fitbit Community @SunsetRunner! I'm glad to hear that everything is working fine for you now! 😄
Let us know if you need anything else!
02-01-2017 06:53
02-01-2017 06:53
I tried the propose solution by FerdinandFitbit but my Blaze still does not light. Suggestions?
08:58
06:49
02-01-2017
08:58
06:49
Hi @toft. Welcome to the Community Forums! 🙂
Is it when you receive call/text notifications that your tracker doesn't light up or it doesn't light up at all?
If you've already checked my suggestions before and nothing works, feel free to get in touch with the Support Team for them to take a look and they'll be happy to help you out!
Let me know if you need more help!
02-01-2017 10:06
02-01-2017 10:06
10:53
06:49
02-01-2017
10:53
06:49
Huh... Mostly this is determined by how you move your arm in order for the Quick View feature to work and make the tracker to light up when you turn your wrist but if you feel like it's totally not working fine, feel free to speak with the Support Guys for them to help you out @toft
03-01-2017 05:47
03-01-2017 05:47
why does my blaze not respond when I raise my hand to have display shown?
