03-02-2016 15:15
03-02-2016 15:15
My Blaze will not pair with my Lg G3. Doesn't even show up when I do a BT scan. I have done all the troubleshooting steps, still can't find it. BT Classic works fine though :(. Not sure if it is my phone (it is on the compatibiltiy list) or the Blaze.
Best Answer03-02-2016 15:20
03-02-2016 15:20
Hello @ScottAZ,
Welcome to the community!
Fitbit trackers do not pair the way conventional bluetooth devices do. To appropriately set up your Fitbit:
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
Best Answer03-02-2016 15:24
03-02-2016 15:24
Doesn't it have to be paired to receive notifications (text/phone alerts)? I had a Surge and it was always paired with my phone.
Best Answer03-02-2016 15:31
03-02-2016 15:31
Yes, but the Fitbit App establishes the pairing on your behalf. If you try to pair a Fitbit by conventional means, it'll likely refuse the pairing.
It also means that when you move to a new phone, all you need to to is install the Fitbit App and log in. No need to mess with bluetooth settings.
Best Answer03-02-2016 17:09
03-02-2016 17:09
Thank you for the info. Would you happen to know why I can't get text notifications on my Blaze?
