06-27-2017 11:42
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-27-2017 11:42
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Who Voted for this post?
For the past couple of weeks my Blaze has not counted any active minutes for recorded workouts. I've had two 55 minute workout sessions (weights & cardio) that have failed to add any active minutes to my day - zero. They show up as counting toward the weekly exercise goal but fail to add any active minutes to the day. But yet a 10 minute walk does get recorded. This doesn't make any sense. Any suggestions?
Accepted Solutions
06-28-2017 07:51
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-28-2017 07:51
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I have gone into the app and found that the trackers calculate active minutes using metabolic equivalents (METs). METs measure energy expenditure of the activity or exercise intensity. A MET of 1 is a body at rest. Active minutes are earned when the MET is at or above 3. And the tracker will only log active minutes if you have 10 minutes of MET 3 or above activity. So, in short, I will have to work harder when I bike. I actually find it hard to believe I am not at a MET 3 with my biking but I will try to ramp it up today. My calories burned for a 50 minute bike ride is in the 160s so not very much.
It looks like if you record workouts manually entering calories is the way to achieve active minutes. Using an online estimator for calories may be the way to go if you are looking to get active minutes.
Hopefully that helps!
06-27-2017 13:34
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-27-2017 13:34
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I don't have an answer for you, but I have the same question. I done two bike rides where my watch shows around 13 minutes of activity, but the fitbit app shows 50 minutes. I too would like to understand the discrepancy.
06-27-2017 18:03
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-27-2017 18:03
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Same is happening with me. And if I go in and manually put in a hike or my work out it takes away a whack of my actual steps! This is brutal! I bought this to use as a help but this past week nothing is working. I'm not even getting notifications of my messages I have turned on to receive. What's up fitbit??!!! Annoyed!!
06-27-2017 18:48
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-27-2017 18:48
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Since active minutes are based on calories, could someone post a screen shot of the calories during the exercise? This is usually where the start of your answer will be found.
Calories are in a big way based on the heart rate, was the heart rate being recorded correctly?
06-28-2017 06:56
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-28-2017 06:56
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Thanks Rich - I'll try to do that next time. As far as I can tell the heart rate was recorded accurately, don't think that is an issue. I understand the point about calories but I can't imagine that my heart rate is higher on a regular walk than when I am doing weights with cardio.
06-28-2017 07:51
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-28-2017 07:51
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-28-2017 08:06
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-28-2017 08:06
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Thanks so much - I'll give that a try.
06-28-2017 14:10
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-28-2017 14:10
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I experimented today by riding faster in order to keep my heart rate up. For a 42 minute bike ride Fitbit recorded 40 active minutes. My average heart rate was 135 and I burned 311 calories.
Compare that to yesterday where for a 50 minute bike ride Fitbit recorded 13 active minutes. My average heart rate was 104 and I burned 169 calories.
The route is 10 miles and was pretty much the same for each day (variation is immaterial). The route is flat.
Good luck!
06-29-2017 05:33
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-29-2017 05:33
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
So the gist is that in order to record active minutes we need to have a greater calorie burn and higher heart rate. Thanks for the help.
11-22-2017 17:15
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
11-22-2017 17:15
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Has anyone noticed the app initially recording active minutes that suddenly disappear? I played golf (walked 18 holes). Initially the app showed 137 active minutes, but when I opened it back up later theu were gone. Not showing up on my watch either.
11-26-2017 05:42
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
11-26-2017 05:42
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
It's great to welcome you @VSalt.
I would like to know if you are manually logging any type of activity that might be taking away your active minutes, like walking or running? If you are manually logging these activities, delete them and see if your information goes back to normal.
Let me know the outcome.
11-27-2017 22:53
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
11-27-2017 22:53
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Irresponsibility - no single raindrop believes it's to blame for the flood.
11-30-2017 03:07
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
12-25-2017 18:38
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
12-25-2017 18:38
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I am not logging activities manually but am still getting 0 minutes a day active. My husband and I have been together the last two days every minute and he's got over 347 minutes active and I've got 0. This is not possible. What can I do?
12-25-2017 19:05 - edited 03-15-2018 13:51
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
@Jsaville870 did you read the information in the accepted solution above?
One thing you can do is make sure Fitbit has the correct weight, height, gender, etc for both of you.
03-14-2018 18:15
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
03-14-2018 18:15
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Who want ms to manually enter calories when I invested money in a device to do it for me!
03-15-2018 13:55
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
03-15-2018 13:55
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
@DjLetigre when you say nothing at all was recorded, are you saying that no record of the event was recorded?
What mode was used to record the event?
@Hollidaz2 what is up? Or what issues are you having?
10-04-2018 06:45
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-04-2018 06:45
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I am having the same issues and not entering activity manually. It just stopped tracking. It will show up in my fitness pal but not the tracker itself or the app.
10-18-2018 10:56
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-18-2018 10:56
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Recording my activity and shows in my exercise that I have worked out. Also my calories are not showing that on day correctly but overnight seem to reset to correct figures. None are manual recording. And my height, gender and weight are set up in my profile. I have just switched to blaze from Alta and not worked since I change correctly? Hope someone can help
11-12-2018 13:49
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
11-12-2018 13:49
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
How is this listed as "solved???!" Isn't the whole point to have a device that records a WORKOUT as "active minutes?" Right now I'm annoyed that the "solution" is to manually enter the activity. Why use the workout function if it's NOT going to count as "active minutes."
Whoever the "Product Owner" is for this feature ... should be fired! 😞
I would include a copy of my screen shot of my workout ... but, your "reply" function doesn't support that, either 😞
