11-02-2016 11:16
11-02-2016 11:16
11-02-2016 11:17
11-02-2016 11:17
11-02-2016 12:12
11-02-2016 12:12
Don't turn it off and everything will be fine.
11-02-2016 13:10
11-02-2016 13:10
11-02-2016 13:15
11-02-2016 13:15
There is no need to switch it off. If you do this you have to accept that you have to sync your device in the morning. Leave it on is the easiest thing you can do. So keep calm.
11-02-2016 17:34 - edited 11-02-2016 17:35
@CJGFitibit This change did take effect after the last update, and was posted by the moderators. You can find the post Here.
Here is the actual verbiage : Important to note: A sync is required after a manual shutdown or a battery drain in order to show the correct time on Blaze. This is especially important for your activity tracked by Blaze because you'll want to make sure it's associated with the current date and time.
If you were not told this by support, not sure why, but they did post about having to sync after a shutdown.
Hope this may help you~
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
11-02-2016 20:33
11-02-2016 20:33
11-03-2016 02:30 - edited 11-03-2016 13:31
I've said this before and I'll say it again:
Remember the game Interstate 76? Never get out of the car? Never turn off the Blaze. That same rule can be applied here.
I don't know why people turn it off all under the guise of "saving on the battery" where there is no anedotal evidence that exists to suggest that you can push the Blaze past the 6 day mark if you do shut it down. I have mine on all the time. At minimum, I charge it every 5 days. Max I can go for 6 days. Sometime around the 6 day mark I'd have to charge it.
