06-07-2017 20:58
06-07-2017 20:58
Hi
i Jus got my new blaze. I've done the initial setup and applied the latest update.
And Im able to use it when in charging cradle.
The moment I take it out the display is not coming.
I tried the basic troubleshooting of restarting, no impact.
Can anyone help
05:03
09:38
06-08-2017
05:03
09:38
Welcome to the Community @Lak2 and thanks for troubleshooting this issue by yourself.
Could you please confirm you are following these steps in order to restart your tracker:
If you are doing these steps, could you please try them again a couple of times.
Hope to hear from you soon. ![]()
Best Answer12-15-2020 05:17
12-15-2020 05:17
There is no solution I could see in post. Can u pl tell what is the resolution to this problem.. really frustrating..
Best Answer12-15-2020 05:18
12-15-2020 05:18
Resolution does not work..
Best Answer12-15-2020 06:04
12-15-2020 06:04
This post was over 3 years ago and it was only beginning the troubleshooting. If you have an older blaze with this issue, it might be battery, might be something else.
Please start your own post with your problem and any steps you've tried so far to fix it.
