05-22-2017 17:51 - edited 05-22-2017 18:10
My dashboard has not registered my sleep or hourly steps for the last week. It shows no sleep and only 1 hour of steps for each day and that's the first hour of each day. My hourly steps show on my blaze and I know I'm sleeping at night.
My heat rate and activity minutes are also not syncing on the dashboard. It stopped 5/15/17. I rebooted my blaze, logged out and back in on my dashboard, but neither has helped.
Thanks!
05-23-2017 01:03
05-23-2017 01:03
Sounds to me like syncing issues. Did you go through the steps in this article for when you have issues syncing your tracker?
Karolien | The Netherlands
05-23-2017 04:46
05-23-2017 04:46
05-23-2017 11:21
05-23-2017 11:21
Welcome to the Community @skeetercat! Thanks for the troubleshoot that you've followed, provided by @Esya! Sometimes, when you're not seeing the same information that your tracker is showing, it's because you're logging into a different account in your Android or computer.
I would like you to check when was the last time your tracker synced: By going to your Dashboard > click on settings > below your tracker's picture you'll see when was the last time it synced. Additionally, provide me with a screenshot of what you're seeing in your Dashboard.
Keep me posted.
05-23-2017 13:59
05-23-2017 13:59
Hello my blaze does the same thing, it's been almost a week since accurate sleep logs.
05-23-2017 15:26 - edited 05-23-2017 15:43
05-23-2017 15:49 - edited 05-23-2017 16:03
Pictures above show dashboard with only 1 hour of steps, blaze that shows I met 10 of 12 hourly steps, and pic showing that my blaze is syncing regularly.
I still am not getting my sleep to show
, or my heart rate.
Thanks!
