Blaze not syncing with my samsung s7
I have to shutdown my blaze 9/10 times to be able to sync it is very frustrating and wishing i never upgraded from the charge.
2 REPLIES 2
Hello @Nat08 When you say shutdown the Blaze, you did this through the settings menu on the Blaze, or was it a 2 button restart.
Have you also done a restart or a shutdown of the Phone?
Also go to the phones BT settings and tell it to forget the Blaze.
Is the app up to date?
It's great to see you around @Nat08 and @Rich_Laue thanks for stopping by. If your tracker is not syncing with your Android device, I recommend following our syncing troubleshoot, after these steps your tracker should sync without an inconvenience.
Let me know the outcome. Woman Happy
