10-18-2018
12:30
05:03
AlejandraFitbit
10-18-2018
12:30
05:03
AlejandraFitbit
My Blaze was fully charged two days ago. When I went to put it on this morning the screen flashed and went black. Though it may just need a charge but when I put it on the charger, it did not show the charger indicator and just had one blue dot in the upper middle of the screen and a pink line across the top. It has been vibrating on and off throughout the day.
05:04
06:39
10-19-2018
05:04
06:39
Hey @MufasaJ3J, it's great to welcome you.
Thanks for troubleshooting this by yourself. I recommend restarting your tracker by doing the following:
I hope this helps, let me know the outcome. ![]()
Best Answer10-19-2018 05:45
10-19-2018 05:45
04:08
06:38
10-21-2018
04:08
06:38
Thanks for the update @MufasaJ3J. Upon checking with our support team, I was told that you have already created a case with them. I know they will be glad to help you out and provide you a solution.
Let me know if you need anything else. ![]()
Best Answer10-21-2018 07:09
10-21-2018 07:09
I am in the same fade to Black position. If Fitbit does not have a repair center in your country and if you are outside the good countries USA and EU then my friend you will have to spend more money. I will switch to the Garmin Vivoactive 3 HR. Garmin tells you to rinse the device in water post workout. How’s that for confidence!!!
