08-09-2017
22:09
04:22
AlejandraFitbit
08-09-2017
22:09
04:22
AlejandraFitbit
I just bought this Blaze, and right out of the box it doesn't power on. When plugged it shows a full charge, but when I unplug it, it doesn't respond to anything. I have set up the account online with the phone the unit plugged in, and confirmation number paired the unit with the account, but it doesn't work when not plugged in. Phone can't pair with it because it is not turning on.
What should I do to fix this mess?
Moderator edit: Subject and format
08-10-2017 04:23
08-10-2017 04:23
A warm welcome to the Community @Niecy17 and thanks for troubleshooting this by yourself.
If your tracker is not working outside the charger, I recommend restarting your Blaze and also, take a look at this post to check that you are properly charging it.
Let me know the outcome.
08-10-2017 12:02
08-10-2017 12:02
08-10-2017 12:02
08-10-2017 12:02
08-10-2017 13:29
08-10-2017 13:29
If you bought it from one of your local stores I would return it for an exchange. Most stores have a 14 return policy on electronic equipment. If your pass the 14 days then I would contact customer support to report your problem. If your blaze is fully charged it should work. It's possible your blaze is defective. Customer support will replace it, they will walk you through some steps to test your blaze to help determine the problem. Good luck
08-11-2017 04:21
08-11-2017 04:21
