01-11-2017
19:53
18:47
DavideFitbit
01-11-2017
19:53
18:47
DavideFitbit
My friend bought me Fitbit Blaze and it's been half a year since I've used it. It was working perfectly fine, and now I want to use it again, but it doesn't work. When I charge it, everything shows, but when I take it away from the charger it doesn't work. Anyone got the same issue?
Best Answer01-11-2017 20:25
01-11-2017 20:25
I've been using my Blaze since April 2016 but it just started behaving exactly like yours in the last two days. I just thought I had been careless when plugging the charging unit into the socket and that's why it didn't charge but I checked everything and it's like you say, works perfectly while in the charging unit, lots of bells and whistles and when you take it out, nada.
Best Answer01-12-2017 04:10
01-12-2017 04:10
A warm welcome to the Community @Susan_Li and @MahatmaOrange. If your trackers are not responding at the moment of taking them out of the charging cable, I recommend restarting your trackers and test them. If this procedure doesn't work, feel free to get in touch with our support team. For a faster response you can contact them via phone or chat.
Let me know the outcome. ![]()
Best Answer01-12-2017 14:42
01-12-2017 14:42
Hi Alejandra
I contacted support yesterday afternoon and they agreed that the tracker battery had issues. Once I could prove that my tracker was still under warranty, they told me they were sending me a new tracker. Hopefully it will arrive soon as my battery is lasting around two hours, perhaps a little more, but certainly shy of the promised 5 days!
01-13-2017 03:07
01-13-2017 03:07
I am glad to hear that you will be receiving a new tracker @MahatmaOrange. At the moment of receiving your replacement device, you can follow these steps to set it up from a computer:
Catch you later. ![]()
