10-04-2019
10:03
09:44
10-04-2019
10:03
09:44
My Blaze is working when connected to charger, but display is getting off when charger is removed.
I think my battery drained completely or not working, need to change the battery.
Want to know how can i contact someone, who can change the battery or any service centres in Pune.
Best Answer10-04-2019 10:13
10-04-2019 10:13
Hi @Avis_10 if you want to replace the battery, you'll need to search online. There are places that sell the parts and they also sell their service to do the work. It all depends on how comfortable you are at working with small interior parts of the Blaze and reassembling it. Sometimes the Fitbit has just come to the end of life.My Blaze made it almost two years and it no longer showed a screen, despite restarting it and knowing it was charged.
10-05-2019 09:47
10-05-2019 09:47
Hi there @Avis_10, welcome on board. Thanks for reporting your Blaze's behavior.
I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here and that they have helped you with this. Please keep an eye on your inbox for updates on your case.
Thanks for all your help and input @Odyssey13.
Let us know if there's anything else we may do to help you in the meantime.
10-07-2019 10:12
10-07-2019 10:12
Thanks @Odyssey13 for the quick response. Can i know the steps on restarting my Device Blaze.
I couldnt found the steps in the Help article from the support.
There's no particular article on how to restart Blaze. So, If you could just mention the steps on how to restart, It'll help a lot.
Best Answer10-07-2019 10:21
10-07-2019 10:21
Sure @Avis_10
To restart your tracker:1.Press and hold the Back and Select buttons (left and bottom right) until you see the Fitbit icon on the screen.This should take less than 10 seconds. 2.Let go of the buttons.
The Blaze user manual is here - click
10-07-2019 10:26
10-07-2019 10:26
Hi there @Avis_10, thanks for getting back.
The steps on how to restart your Blaze can be found at: How do I restart my Fitbit device?
I'm seeing that you're still in touch with our Support Team. Don't forget to keep an eye on your inbox so they can continue assisting you on this matter.
Let me know if there's anything else I may do to assist you with.
10-07-2019 10:45
10-07-2019 10:45
Hi @MarreFitbit actually, that part of the reset information needs to be changed. It says Blaze, but when you click, it only shows the Versa information.
10-07-2019 13:05
10-07-2019 13:05
Thanks for pointing this out @Odyssey13. Fitbit Blaze can be reset the same way as Fitbit Ionic and Fitbit Versa since these three belong to the same family.
Fitbit Versa Lite Edition and Fitbit Versa 2 need to be reset differently, as described in the article you shared with me.
I really appreciate you have taken the time to let me know that we need to add the word "Fitbit Blaze" to the instructions to make the steps more clear for our users. I will definitely pass this along to our team so we can add it as soon as possible.
I hope you're doing great! 😉
10-07-2019 23:13
10-07-2019 23:13
I really appreciate you both, thanks for all the info.
I think i need to change the battery.
Any ways Thanks
10-08-2019 07:29
10-08-2019 07:29
@Avis_10 look online. There are places that do sell the battery and some places will install it for you.
