06-11-2017 05:54
06-11-2017 05:54
So I've had my blaze for about 9 months and now it won't hold a charge for more than 5 or 6 hours and I charge it until it's completely charged with the green battery showing but it won't stay charged
Best Answer06-11-2017 06:21
06-11-2017 06:21
Might be a third part app @wepender if everything wasOK to this point.
Best way to isolate is to swipe over the settings, tap, tap off quick view, make sure brightness & heart rate is tapped for "auto", then tap shutdown.
Go to your dashboard settings
"applications" on the left and revoke access for everything but fitbit apps
turn your blaze back on by pressing the left button
how long before your tracker (not emails or alerts) asks to be fed ?
(watch for red icon in upper left of "today" logo screen, usually means 8-10 hrs left)
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
Best Answer06-13-2017 10:42
06-13-2017 10:42
Didn't work @wmchapman
Best Answer06-13-2017 16:44
06-13-2017 16:44
OK, so hardware.
Press and hold the left and bottom right buttons until your Blaze vibrates, then let go.
Put in your charge cage and let it charge exactly 2 hrs.
When you put your Blaze back on force a sync by touching and pulling down on your mobiles fitbit tile screen - the battery should show full when you check it.
Don't charge it again until the Blaze asks (red indicator icon in the upper left of any Blaze screen except the clock) was it more than a day?
WmChapman | TX
Best Answer06-26-2017 03:32 - edited 06-26-2017 03:33
@wmchapman Still didn't work the battery lasted from 10:00pm until 3:00 am
is there a way to contact fitbit since I haven't had this watch for a full year yet?
Best Answer06-26-2017 05:48
06-26-2017 05:48
Chat is the fastest 🙂
Be prepared to let them know what you've tried.
WmChapman | TX
