08-25-2018
08:50
04:36
AlejandraFitbit
08-25-2018
08:50
04:36
AlejandraFitbit
Below are the few issues which is happening very often.
04:35
17:00
08-26-2018
04:35
17:00
It's great to welcome you @nkyr.
I am sorry to hear about the issues you are experiencing with your Blaze. If your Blaze is already paired, it shouldn't ask you for the 4 digit code, since this only works when you are pairing the device.
If your tracker isn't paired, that will explain the connection, time and syncing issues. Please follow the instructions provide in the help article How do I set up my Fitbit device? to setup your tracker. About the LED lights, you can try to restart your Blaze and verify that the heart rate option is "On" or "Auto".
Let me know the outcome. ![]()
