06-16-2018 07:16 - last edited on 06-18-2018 06:28 by AlejandraFitbit
Woke up and it was frozen on the hot temperature screen. I tried the hard reset but it's still frozen. It's 70 degrees in my house! Please help!
06-16-2018 07:22
06-16-2018 07:22
That's actually a "lost connection with battery level report" screen Spaw.
Check bluetooth on your mobile and make sure your tracker is still connected.
If it is, go to the fitbit App home screen, touch and pull down to force a sync.
Does the battery level show up in the upper corner?
If not, try rebooting your phone and your Blaze after charging at least 15 minutes.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
06-18-2018 06:30
06-18-2018 06:30
Welcome to the Forums @Spawman and @wmchapman thanks for stopping by.
I appreciate the efforts in trying to fix this temperature issue and I am glad to see here that the instructions provided by our friend worked, or are you still experiencing issues with your Blaze?
Hope to hear from you soon.
06-22-2018 07:26
06-22-2018 07:26
Uh actually your buggy system would NOT let me uncheck the "accept as solution" when I replied to him.
My fit bit is STILL frozen on the hot temperature screen and I am very disappointed that there has been no solution to this issue.
Maybe you should read the actual reply next time.
06-22-2018 07:28
06-22-2018 07:28
Still frozen...
06-22-2018 18:43
06-22-2018 18:43
Thanks, super helpful. But I am guessing you have never seen the bright orange screen with the triangle surrounding the thermometer, which I'm pretty sure has nothing to do with Bluetooth. I just saw it today for the first time and even not being a computer genius, like the many helpful people here, knew it was temperature related. The hot little FItBit in my palm told me that. Oddly, I saw a red dot for the first time today too, in the upper left corner of the screen. Red for Bluetooth, probably, so I let it cool off for a couple hours and put it in the charger. It appears to be half charged now. I charge it only when I am in the shower, so about 10-15 minutes about 5-6 days a week. Been having sync issues and GPS issues for a bout a month.
06-22-2018 22:00
06-22-2018 22:00
06-23-2018 18:40
06-23-2018 18:40
So, I got 20 minutes into the charge when the temperature icon returned. The battery drained within minutes after that. The battery was drained all day today, off the charger, and I just put it in the charger a while ago and it appears to be charging. The interesting thing is yesterday afternoon, I used the exercise function to map a walk and lost GPS in the first 10 minutes, I just switched over to the FItBit app on my phone to track the walk and the Blaze vibrated about every 5 minutes so I cancelled the walk on it. It was a warm sunny day, so maybe the combination of all the vibrating, repeat attempts to connect to the phone for GPS, the sun and the ambient heat heated the battery up. All speculation on my part, but I have had my phone heat up sitting in the sun, so, who knows. The really concerning thing to me here is that lithium ion batteries have been known to heat up and explode. I would think that this should concern the developers at FitBit, if we are seeing what appear to be heat warnings.
06-27-2018 05:34
06-27-2018 05:34
Thanks for the update @Spawman and welcome to the Community @rlombardo.
Since the instructions you have tried didn't work, I've gone ahead and escalated your cases to our Support Team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Let me know if you need anything else.
07-19-2018 15:18
07-19-2018 15:18
Having same issue here
Will not 2 button reboot
What steps are next?
01-30-2019 05:16
01-30-2019 05:16
My Fitbit blaze has the temp icon as well. I was charging it and it turned to this icon. Does anybody have a solution please?
01-30-2019 05:18
01-30-2019 05:18
Yes. I did end up finding a solution. I bought the Samsung Gear S3 frontier. Trust me, it's worth it.
01-31-2019 08:30
01-31-2019 08:30
Did you ever get a reply?
01-31-2019 08:33
01-31-2019 08:33
Just some nonsense from a guy who copy and pasted from the same article I already read. I gave up and got the Samsung Watch. It was so worth it
01-31-2019 08:59
01-31-2019 08:59
01-31-2019 09:03
01-31-2019 09:03
Mine has had the temp icon for 6 months
I have replaced it with the Ionic which is great!
But can someone explain how it can sit in my junk drawer for 6 months without being charged and still have enough power to show the high temp icon?
01-31-2019 09:30
01-31-2019 09:30
02-12-2019 17:40
02-12-2019 17:40
My Blaze is showing same icom. The green sensors doesnt work anymore. And previously the battery didnt retain energy as before. I think It is gone after one year of use.
02-12-2019 17:59
02-12-2019 17:59
Message them
They'll give you a good deal on a new one
Mine is still showing it
Been in a drawer for months
12-19-2019 06:21
12-19-2019 06:21
I guess it's worth trying to install air conditioner to decrease the temperature of the air
