Blaze syncing and battery issues
My Blaze worked flawlessly for the first 10 days. Then it wouldn't sync through Bluetooth. The only fix was delete the device in the Fitbit App & Bluetooth App then completely reinstall like it was a new install. The only workaround is to take it off and cradle it with the USB plugged into the laptop. Also, it was completely charged before bed last night and now it is <40%.
Any ideas?
1 REPLY 1
It's great to welcome you @GH2018.
Thanks for troubleshooting this by yourself. I recommend taking a look at the following links and follow the instructions provide:
I hope this helps, let me know the outcome. Robot Happy
