Blaze syncing with Nexus 6p running on anroid N but wont GPS is not working
After the third update from google today blaze is syncing with fitbit app on Nexus 6P  running on anroid N. But the when i try to connect phone GPS for running .. blaze display's following message " check your fitbit app"
can anyone help how to solve this problem
2 REPLIES 2
Welcome to the Community @nihag. First, I recommend checking if your phone is a Compatible Mobile Device. If it is, I recommend restarting your phone and your Blaze. After the restart process, test your tracker.
Let me know the outcome. Woman Happy
Are you able to receive your Nexus 6P text and calendar notifications on the blaze? I'm on N preview 3, too.
