Blaze touchscreen not working and battery not lasting
After last update of Fitbit with iOS, the touchscreen of my Blaze isn't working anymore. Battery is also holding for less than 18hrs. Any clue? Did it happened to someone else?
3 REPLIES 3
It's great to see you participating in the Community @THIBS3.
If your tracker display isn't working, I recommend restarting it. Now about the battery issue, in this post you will be able to see some instructions to follow.
Let me know how it goes. Robot wink
Pushing the left button doesn't restart the Blaze.
I'm waiting for the battery to go completely dead and hopefully recharging will reset everything.
I'm doubtful but let's wait and see.
Thanks for the update @THIBS3.
Since the troubleshoot provided didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Keep me posted. Robot wink
