03-10-2016 05:03
03-10-2016 05:03
Best Answer03-10-2016 05:14
03-10-2016 05:14
If you are going to cary your phone I would get the Blaze and allow the GPS on your phone to do the tracking thru the watch app. It works great on my iPhone.
I have the Surge but it is ugly compared to the Blaze but if you ONLY wear the Surge while working out you might want to reconsider.
Best Answer03-10-2016 07:10
03-10-2016 07:10
If you are bringing your phone on runs all the time anyway, there is no reason not to go with the Blaze and use the connected GPS feature.
03-10-2016 08:02 - edited 03-10-2016 08:03
If you always carry your phone I would get the Blaze. I like the surge but I like the Blaze a lot more do to the colors and the sleek look of it
You should go to a store and look at both. You will make a better decision
Wendy | CA | Moto G6 Android
03-10-2016 09:26 - edited 03-10-2016 09:30
@PWF5 since you carry phone while running, I recommend either the One or Blaze because:
- Surge integrated band is prone to early failure, and entire unit must be replaced. In particular the band starts failing around the screws on back, leading to condensation in display.
- Surge is big and bulky, I'm a big guy and find it too big and frankly ugly.
- due to Surge size, it tends to move around on your wrist and that interferes with heart rate monitoring accuracy.
- if you care about HRM accuracy, because you run intervals and do over/under threshold work, then Fitbit isn't the best choice as PurePulse isn't so pure and you can't use chest strap. Read DCRainmaker reviews if you care about HRM accuracy.
I believe Fitbit will eventually replace Surge with something that looks like Blaze. After returning Force due to recall I'm using MobileTrack - my iPhone 5s is Fitbit tracker. Personally waiting until "Blaze 2.0" appears (actually I'm hoping its "Surge 2.0"), as MobileTrack works well because my phone is always in pocket and notifications on Apple Watch are awesome, and AW does a better job tracking my weights/cycling workouts vs Blaze. I even get Fitbit app notifications on my AW, including messages and challenge updates.
Blaze is very nice addition to Fitbit lineup although a bit large for my tastes. Like anything these days, there are a few annoying bugs at launch but those should get fixed soon. MobileTrack works for me right now, but its not for everyone, so if you want a nice Fitbit tracker with a display then Blaze looks pretty sweet. Both the One and Blaze are my recommendations.
03-10-2016 11:01
03-10-2016 11:01
03-10-2016 11:17
03-10-2016 11:17
Great insight, thanks to @bbarrera @WendyB @KisaraKaiba @SunsetRunner! Let us know what you choose to move forward with, @PWF5!
Best Answer03-11-2016 00:44
03-11-2016 00:44
Best Answer03-11-2016 18:24 - edited 03-11-2016 18:25
I actually "downgraded" from the Surge to the Blaze this week. Who knew a downgrade would be an upgrade? The Blaze is much lighter on the arm, less bulky, and the band is more flexible. I love the Color UI and it makes the Surge look like 5 year old tech. I really love it. I did a comparison between the two and both counted steps accurately. I even believe the GPS works better on the Blaze because of the high accuracy of phone GPS. It caught little movements that my surge never picked up on. I'm really happy with the Blaze. ![]()
Best Answer03-11-2016 18:37
03-11-2016 18:37
Best Answer03-11-2016 19:57
03-11-2016 19:57
Blaze is cheaper and better looking than the Surge; you will get more use from it by wearing it daily. For some reason, I have a difficult time imagining women liking something like the blaze or surge, unless it is for working out... It just seems larger than a watch that a lady would like to wear out at night or to work, but a lot of ladies on here have said they love it!
Best Answer03-11-2016 20:17
03-11-2016 20:17
I as a man feel the Surge is to big for daily wear, which is currently the Charge HR for me. The Surge is reserved for times when i know I'll be hiking are walking.
Best Answer03-12-2016 08:09
03-12-2016 08:09
Best Answer06-29-2016 09:48
06-29-2016 09:48
Interested in the same thing. I have the Surge and have babied it. I have babied it so much that the inevitable serew cracks on the back didn't occur until 1 month and 1 day out of warranty. I am no longer eligable for a replacement but for 25% discount. To me this makes the Surge no longer a durable fitness device but that holy grail for most tech companies Surge-as-a-subscription. You renew yearly, or every 13 months in my case, by using the 25% discount to purchase a new device. Sounds like a strong business plan if you discount annoying your customers. I'll be purchasing a Blaze with the hopes of it lasting longer than a year. My One is still kicking after 3 years.
05-18-2017 18:38
05-18-2017 18:38
I love my surge, but only because it takes a beating better, my father has a blaze and is a cop and had to get his fix idk how many times but he started using the surge for about and it hasn't broken on him yet, he had hit it against walls, doors, and people and not even a scratch, so there are no complaints thwrw
13:08
09:06
05-21-2017
13:08
09:06
Hey @tryingtolose1. Great to see you in the Community Forums and thanks a lot for sharing your feedback on this. I really appreciate it!
If there's anything you may need, let me know. I'll be happy to help!
