Blaze will not charge its battery
I have had my blaze hooked on the charger for over 24hrs now and it is still dead. Black screen, no green lights on the back flashing, nothing, so I cannot even try the restart solution to this problem. I need help.
1 REPLY 1
It's great to have you here @VEblaze! Thanks for the details you've mentioned. I would like you to confirm you're properly charging your Blaze and that you've cleaned the contacts
Additionally, I've shared your post with Customer Support they should reply to you within the following days.
Hope this helps!
