11-23-2017 09:47
11-23-2017 09:47
My Fitbit blaze has a black screen and won't even show the logo when in the wrist band. It says it's fully charged when on the charger and on the app and will also fully function when on the charger.
Best Answer11-23-2017 10:32
11-23-2017 10:32
I have the same problem with my Blaze. Can someone help?
Best Answer11-23-2017 10:38 - edited 11-23-2017 10:38
I am having the same problem I purchased the item yesterday
11-23-2017 10:38
Yesterday
Best Answer11-23-2017 17:13
11-23-2017 17:13
Hi
i have the exact same problem..have u gotten a solution yet?
Best Answer11-23-2017 17:37
11-23-2017 17:37
I have the solution:
hold the left button and the right lower button it will reset and the Fitbit logo will appear. I am not sure why the issue occurred. Hope this helps everyone.
11-23-2017 17:41
11-23-2017 17:41
Best Answer11-23-2017 21:05
11-23-2017 21:05
I have this same problem. I have tried everything resetting it and nothing works. The screen is just black out of the charger
Best Answer11-23-2017 22:08
11-23-2017 22:08
11-26-2017 05:37
11-26-2017 05:37
Hello all, I hope you are doing fine!
I would like to know if you keep having issues with your trackers? If you do, as suggested, please restart them by doing the following:
Also, take a look at this post to make sure you are correctly charging your devices.
I hope this helps, let me know the outcome. ![]()
