Blaze won’t charge due to burnt pins on watch
Used to wear my blaze religiously, bought my wife a versa and an ace for all of my kids. then started to have issues with my blaze not holding a charge and inconsistent charging and battery life.
Had it on charge one day and it didn’t charge, when I inspected it the parts that the pins on the charger connect to were burnt !!
I always cleaned it religiously so it didn’t stink or get damaged. Just wondering if anyone else had a similar issue ? I will post a picture when I dig it out
2 REPLIES 2
Doesn't matter about the picture. It will not charge at all. Get with support to see what your options are
Community Council Member
Wendy | CA | Moto G6 Android
@The_Hedgehopper   Did you try cleaning the pins with rubbing alcohol and a toothbrush?  This is one of Fitbit's recommendations if your device won't charge.
Laurie | Maryland
