08-14-2018 23:16
08-14-2018 23:16
My Blaze had a vibration frenzy when I put it on the charger to charge. It didn't charge, had a red thermometer and was hot. I've tried the reset feature several times to no avail. Won't charge either.
Best Answer08-14-2018 23:58
08-14-2018 23:58
Please dont try to charge it again and contact support
Contact Support
http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
Wendy | CA | Moto G6 Android
08-14-2018 23:58
08-14-2018 23:58
Contact Support
08-15-2018 19:47
08-15-2018 19:47
Thank you Wendy. I will contact support with the link that you provided. I appreciate your reply.
Best Answer08-15-2018 20:01
08-15-2018 20:01
They are sending me a shipping label to return the unit and assure me that they will send a replacement. Thanks again!
