Blaze won't charge out of box - needs to do update - can't update without charge
This is my 6th - brand new out of box blaze. I'm having the same problem with All of them - not only me but 4 other people in-store all trying to do the same - I first purchased my blaze 10mhs ago - great, no problems at all .. blaze worked perfectly. 4 weeks ago there was a firmware update since then my blaze battery would only last, at best - 1 day & that's with all notifications off! B4 this, it would last 4 days at least and that's with logging my workouts from gym and all notifications turned on! I tried 3 nights in a row doing a full charge each night - it would charge fully fine but the charge would only last 1 day. Knowing something was wrong I returned it to the store I purchased it from. They agreed, something was wrong - handed me a new one (in exchange) - great! Went home to set up new device (this is my 4th Gen Fitbit - not my 1st time trying to use a Fitbit device) - So, 1st deleted the old blaze from both my Samsung S8 & Surface Pro - restarted devices - turned on Bluetooth to begin setup for syncing blaze. Bluetooth on both phone and PC recognised blaze every time no problems there - asked to enter 4 digit pin each time - all fine - next step... blaze needs to do a software update to complete set up -this is the problem -  blaze can't charge b4 setup. Plugged blaze charging cradle directly into USB to charge - Yes, It was connected fine - charged for 3 hrs & nothing - screen still reads Fitbit.com/setup - Checked cradle connection - via connected devices on computer - cradle showing up as a connected device fine! Still, blaze not showing battery charging. Next, tried to charge via usb directly over night - nothing! Blaze screen still says fitbit.com/setup. Tried plugging directly into wall - same! Took 2nd brand new blaze back to shop - exchanged for new one Again! ...Round 3 - Deleted ALL Fitbit related apps from ALL devices and started the process over again from the beginning - still having the same problem - took my brand new computer into store I purchased it from only 4 weeks ago (keep in mind 1st blaze was connected to this device and working fine b4 update) - 3 tech guys working on it couldn't get the blaze connected - All had the same problems - they even tried opening 2 more brand new -out of box blazes and connecting them with other devices in store - Nothing, they all had the same problem! After leaving it with them overnight - they still couldn't get any of the devices to work - 3 qualified technicians can't get any of the 4 brand new out of box blazes connected - All had the same problem - Yes, we know how to reset the device - Yes, we tried different power sources and even tried different charging cradles for ALL of them - Nothing has worked! So, after all this we contacted Fitbit directly - Fitbit sends me out a new device (arrives 1week later)  try to set up - same dam problems! THIS IS A SOFTWARE PROBLEM .... No-one at Fitbit knows how to fix it! Everyone is having the same issues! You'd think they'd send out a brand new device with the new update already on the device - considering all the issues we've had - Nope! They send me out another blaze that still requires me to do an update on a device that can't complete setup without charge - can't charge without setup first.... - Grrr I'm so mad!!!! Will be sending this device back to Fitbit for a full refund! The only good thing about Fitbit is the App - the devices are crap and I'm so over trying to get it working! Fitbit need to delete the latest update required - fix the issue then try asking customers to except the update at their own time when an update can be done correctly!
3 REPLIES 3
I like your one paragraph post.
The tracker will only display the setup message until it is setup.
As long as you feel a vibration when plugging it in to charge, it is charging.
Now after three hours have you tried setting it up again?
1 paragraph post because I'm typing in a hurry - Sorry, just really over it!
No-one has offered any viable solution to fix this issue so far & I've tried just about everything!
Tracker showing in Bluetooth as connected - As is charger when plugged into USB.
Yes - I feel a vibration when plugging it into the charging cradle - it also sounds on my PC that something has been recognised AKA - is connected!
We've tried set-up about 30 times - Deleting & restarting from beginning on all devices - tried resetting blaze - lost count how many times I've rest - reset always shows fitbit logo on blaze screen followed by red battery on screen (2 -3 red bars - indicating flat battery)  - plug blaze into cradle to charge screen show's fitbit.com/setup - leave for hours, It won't charge!
I've tried charging via computer USB & wall both. Left to charge both ways for hours at a time - still nothing!
I've tried 3 different charging cradles - All brand new - still nothing!
Screen on blaze still says fitbit.com/setup - even though its given a pin to connect and says its connected in the Fitbit app! The app is showing blaze is connected with flat battery symbol next to blaze - Under blaze logo in Account app is showing  - "Update is available" - when I click on the blaze icon in app account it says "update your tracker".
When I click to update, it first say's "looking for tracker" ... then says "could not complete update" -  ...blaze battery requires charging - it won't update until charged & won't charge without completing setup... Can't complete setup without charge! ...Double edge sward thing going on here!!!!!
I've tried doing the setup via Wi-Fi & without - this didn't work
I've tried with my phone directly - didn't work
Tried resetting - turning off Bluetooth - restarting phone & PC each time- still nothing!
This is the 6th brand new-out of box blaze we've tried - we've tried set-up with 3 different accounts on 5 different devices - All brand new devices - still nothing - tried changing to classic mode via dongle - still nothing!
Anymore suggestions? Would love to hear something that actually works - So far we've tried every suggestion given in this forum and none of them have worked.
Tried contacting Fitbit - their solution was to send me a new device - Received new device & same problem still with set up!
Would like to know if anyone in Australia that has purchased a new Fitbit in the past 2 weeks that's been able to setup their device without any problems doing the update?
The Blaze will charge without updating. The only notice that it is charging will be the slight vibration when plugging in.
If you have a win 10 or Mac you may do the update through the charging cable and by pass Bluetooth completely.
