12-02-2021
09:28
04:37
12-02-2021
09:28
04:37
My blaze was low on battery so I plugged it in and after a few hours it was still low. Then it suddenly turned off (while in the charger). It doesn’t charge, turn on, or respond in any way. I’ve tried the charger in different plugs and ports and nothing. My friend tried my charger with their blaze and no problems. I also tried their charger and still nothing. I’ve had it less than a year so it’s pretty upsetting.
Best Answer12-02-2021 10:06
12-02-2021 10:06
Hi @KCHarrison that's what happened to mine when it died. See if customer support can tell you how the battery looks. They can "see" more on their side and might be able to let you know something.
https://myhelp.fitbit.com/s/support?language=en_US
