02-19-2018 03:55
02-19-2018 03:55
Bought new Fitbit blaze to my Samsung s8.
It doesn't work!!!! I can't use it for exerice since it can't connect, never. See picture.
Spare me for the standard fitbit-answer, I have already rebooted watch and phone several times .
This is the most frustrating product ever. All the other watch, Samsung gear , garmin, even the cheap Chinese watch connect at once without problem. This is not good enough!!!!!!!!!!!!!!!!
02-19-2018 08:58
02-19-2018 08:58
Maybe turn bluetooth classic on in the settings? Not sure if that'll fix it but it might help
02-20-2018 04:04
02-20-2018 04:04
I have the exact same issue. I have to open the app to get it to sync before I can track anything. Then most of the time within a few minutes its disconnected from my phone and I get no speed/distance reading or the result is absolute nonsense.
Using a Galaxy S7 and have also rebooted, re-installed app, turn BT off and on, reset the fitbit and tried classic off and on. Just seems to be that fitbit is not reliable
