05-09-2017 06:13
05-09-2017 06:13
Hello all,
I just purchased the Blaze last night, and got everything up and going on it. The phone call notification works, calendar notification works, but it will NOT display any incoming text messages to my phone. It appears to be syncing but not my texts. Any help is appreciated. thanks
07-31-2019 05:53
07-31-2019 05:53
I know they've said that about the s10. If everything else functions ok for you except for this issue, I'd say when they fix this bug(hopefully soon) your watch would work fine with the s10. Mine too!
08-01-2019 06:18
08-01-2019 06:18
Same problem with my Blaze and they tried to tell me it was my phone. I explained that was interesting since it seems to be a common problem per their Forum.
08-01-2019 13:07
08-01-2019 13:07
Yes I believe I'm DONE. I have uploaded the old version 2.90 app yet it works but every evening it States New update. I said NO. Now its started disconnecting from my phone every time I walk out of the room. I believe this is the end of the Fitbit for me. Samsung watch is looking better and better.
08-01-2019 15:31
08-01-2019 15:31
You have to turn off your auto updates, and you should not have a problem.
08-01-2019 18:58
08-01-2019 18:58
I have and yet it still tells.me a new version is available. They just need to come up.with a fix.
08-01-2019 19:11
08-01-2019 19:11
Wow.....
If you've gone into the app play store, found the Fitbit app and de-selected the auto update feature and you're still getting nagged about updates? That's a head scratcher.
08-05-2019 10:15
08-05-2019 10:15
Hello all, thanks for your participation in the Community.
I am sorry for the delay in respond and appreciate all the efforts in trying to fix this notifications issue. @e-m-m-a, @Smsculley, @MomOfDVan, @CYBERSIS1 and @317_topchef, thanks for the input.
@shrtstf, @chevygirl10, @Heather_U1, @Melissa2017, @JuddRanch, @sbecertified, @BRUNx, @Aprildixon1998, @RemWin and @Sligh, if you are having problems with your notifications, I recommend taking a look at the help article: My Fitbit device isn't receiving notifications from my phone and follow the instructions provided there.
Also, I recommend checking the article: Which phones and tablets can I use with my Fitbit watch or tracker? and see if your phones are compatible.
If the issue is directly with the Textra app, as mentioned previously, our team is aware of the problem and are working to resolve it as quickly as possible, sorry for any inconvenience it's caused and appreciate your patience and look forward to getting you back on track.
@SunsetRunner, if you are seeing a pending update, I recommend updating your app by following the steps in the article: How do I update the app to the latest version?.
I will see you around.
08-05-2019 10:28
08-05-2019 10:28
I really hate to get rude but I guess the situation calls for it after the ridiculous canned responses we keep getting. People time and again keep saying they get notifications, just not TEXT notifications.
@AlejandraFitbit Why the heck would I update the app to the latest version when I and many others have plainly demonstrated the latest versions of the app (anything at or beyond v3.0) is what is CAUSING the issue?!? I am definitely done with Fibit. I really liked the two I had over the last 3 years but this has gone on for too long. Had the community not discovered a fix OURSELVES my device would be borderline useless and its obvious that Fitbit has no desire to fix this in a timely manner, if at all (which I believe more and more everyday to be the case). If they had said early on we are going to no longer support it, it may have been understandable but for them to not even acknowledge a screw up is unacceptable. We have already replaced my wife's device with a Samsung one and I will be doing the same myself.
08-05-2019 18:10
08-05-2019 18:10
08-06-2019 08:38
08-06-2019 08:38
08-06-2019 16:40
08-06-2019 16:40
You moderators should know by now the problem is with the updated version of the Fitbit app. And that is the only problem. Fitbit needs to admit that and fix it. Do you not look at the post here. When people uninstall the new version and reinstall the 2.9 version we start getting our messages again.
08-06-2019 19:44
08-06-2019 19:44
The problem is only with certain phones. Or maybe just some versions of the OS.
For many notifications work fine with the latest app.
08-06-2019 20:33
08-06-2019 20:33
If you read through my previous dissertation ( yes, I know it was long!) I mention that my understanding with new software there is the possibility of it not being fully backward compatible with older product and that Fitbit R&D may not want to expense the bug fix for older product. If that's the case then there should be multiple versions of software available. But that would be expensive also. I don't know what they'll do. I just know that my watch works fine with Version 2.90 and if that's the way it is then, oh well. I don't feel like plunking down $200 -$300 for another watch.
08-07-2019 10:22
08-07-2019 10:22
Looks like version 3.3 has hit the Google Play store. Anyone want to be the guinea pig? Personally I don't really want to.
08-07-2019 11:39 - edited 08-07-2019 11:43
I may give it a whirl but in looking now in my Android Play Store I only see Version 3.2 as of yet. If I do I'll post unless somebody beats me to it. My curiosity is itchin to see if they did anything to retro the Blaze notifications.
08-07-2019 12:24
08-07-2019 12:24
I have the Samsung 9 and with the update it is doing the same thing for me as well, this has to be something with the update, I have also check and did all the required steps to my phone and fitbit.
08-11-2019 19:31
08-11-2019 19:31
08-12-2019 05:53
08-12-2019 05:53
08-12-2019
07:52
05:02
JuanJoFitbit
08-12-2019
07:52
05:02
JuanJoFitbit
This forum won't let me post the name of the website I found it, but if you Google "Fitbit Version 2.90" the first website that came up is the one I used. The website had several versions available all the way from Version 3.2 back through Version 2.89. I downloaded 2.90. I have an Android. Your phone will fuss that the software is not coming from the play store. I scanned it with Bitdefender and decided to use it. I completely removed 3.2 and installed 2.90. Works fine. I also went into the play store, brought up Fitbit App, and opened the upper right corner 3 dots. Unselected auto-update.
Yep. Silence is not golden in this circumstance!
Moderator edit: merged reply
08-12-2019 12:44
08-12-2019 12:44
Hello,
I have been following this thread and looking for the older app version when I found "Fit Notifications (for Fitbit) app by Smart Dinosaurs entertainment. It give me 6 steps - turned it on and every text message is working with previews.
Good luck all. I cant wait until this is fixed.
