05-09-2017 06:13
05-09-2017 06:13
Hello all,
I just purchased the Blaze last night, and got everything up and going on it. The phone call notification works, calendar notification works, but it will NOT display any incoming text messages to my phone. It appears to be syncing but not my texts. Any help is appreciated. thanks
09-02-2019 07:10
09-02-2019 07:10
09-02-2019 07:20
09-02-2019 07:20
@Aprildixon1998 your post simply confirms what Fitbit has been staring. That they are aware of notification issues with a few phones running Android 9 and has nothing to do with the tracker.
I also notice that you have an S10 which still is not on the tested and made sure to work list
09-02-2019 18:15
09-02-2019 18:15
09-02-2019
18:47
05:06
JuanJoFitbit
09-02-2019
18:47
05:06
JuanJoFitbit
If you look at this thread history, you'll find several people including myself that have said how to do it. But anyways, Google Fitbit Version: 2.90. I used the first website that came up. Can't tell you name because this forum won't let me. Download version 2.90. Once sure you have it, remove version 3.20 from phone. Find Version 2.90 in phone and click on it. Phone will fuss that it's not from approved site. I ignored and loaded anyways. Set all notification parameters as you have. Go into phone settings and find Fitbit app. Make sure all notifications are enabled, email, SMS, etc. Go into play store, find Fitbit. It will want to update. Don't. Click on 3 dots upper right. De-select auto update or it'll nag you and auto update.
Make sure you go to your phone's settings > Notifications & Apps > Apps > Fitbit app > Notifications and allow all the permissions.
Moderator edit: merged reply
09-02-2019 19:22
09-02-2019 19:22
Your assistance in this thread has been less then helpful and less then forthright.
Please stop convoluting the information.
This is a FitBit issue. It IS NOT a phone issue.
09-03-2019 08:45
09-03-2019 08:45
09-03-2019 16:56
09-03-2019 16:56
Anyone else notice that at some point over the weekend it worked? I can't say when for certain as I wasn't wearing it, but noticed I had readable messages i received on Sunday and Monday...none since.
09-04-2019 08:35
09-04-2019 08:35
Version 3.5 just came out. Text notifications are still broken....
09-04-2019 15:10
09-04-2019 15:10
Good to know, I went back to 2.9 version where everything works. Waiting for a fix to come out but starting to really doubt one will. When my blaze gives out, going to Samsung galaxy watch.
09-05-2019 04:37
09-05-2019 04:37
You would think the Fitbit programmers would quality check their updates before they post them. They had to know their updates did not work with all watches.
09-05-2019 05:56
09-05-2019 05:56
I did the latest update and mine is working just fine now. I have the Blaze and a Note 8 phone
09-05-2019 18:04
09-05-2019 18:04
I downloaded the latest version and you're right......it's working on my blaze and note 8. Thanks for the info.
09-07-2019 08:27
09-07-2019 08:27
Going back to version 2.9 also worked for me. Google Pixel XL with Google Messages as my default sms app.
How do we know when the bug in a new release has been addressed? The release notes are not specific enough to tell.
09-07-2019 09:44
09-07-2019 09:44
Another person recently posted that they updated to the latest Version 3.5 and it worked for SMS messaging. I have not had the time to mess with it yet but was wondering if anybody else has tried this version yet with positive results? I have not seen any posting from Fitbit about a bug fix being out there for the Blaze.
09-07-2019 09:55
09-07-2019 09:55
09-07-2019 09:59
09-07-2019 09:59
I just tried 3.5. It did not fix the issue, so I reverted back to 2.9. I'm on an unlocked LG G6 running Android 8.0
09-07-2019 11:35
09-07-2019 11:35
The 3.5 fixed mine. I have a note 8 and the blaze.
09-07-2019 17:38
09-07-2019 17:38
I have a Fitbit blaze text messages do not show, or phone calls I have a galaxy j7, any tips would be greatly appreciated
09-07-2019 18:24
09-07-2019 18:24
09-07-2019 21:06
09-07-2019 21:06
