12-16-2016
19:50
17:48
DavideFitbit
12-16-2016
19:50
17:48
DavideFitbit
My fitbit blaze won't hold a charge for more than a day and it won't sync to my phone. It was working just fine 2 days ago. The time is way off as well but, I think that is just because it won't sync. What do I do?
Best Answer12-17-2016 01:12
12-17-2016 01:12
Normally I would say try the two button restart by holding down both the Left and lower Right buttons. However I have the feeling it is more of a hardware lock up up and will recommend going to the settings men I. scrolling to the bottom, and doing a shutdown of your Blaze.
Then press any but on to turn it back on.
Best Answer12-20-2016 05:01
12-20-2016 05:01
I am having the same exact issues. I have not been able to sync my Fitbit to my phone since 10/26/16.
I did the shut down and restart multiple times. Does not make a difference. Now it no longer holds a charge.
I think I will be returning it or seeing if the store with exchange it. It's not even 6 months old and I'm having these issues...
