10-07-2017 17:31
10-07-2017 17:31
I have had my Blaze for almost two years with no problems. Now it will only hald a charge for less than a day, and it won't read my heartbeat anymore. Please HELP!!!
Best Answer10-08-2017 02:45
10-08-2017 02:45
Any chance you can see moisture in the heart rate sensor? The plastic membrane over my sensors has a hairline crack that allows sweat into the sensor area... and creates your exact symptoms.
I let it dry out, put it on the charger for a couple days, (more heat and drying?) I put scotch tape over the sensor crack, and it’s gone back to normal. If water sealing a watch with scotch tape is normal...
Best Answer10-08-2017 02:47
10-08-2017 02:47
See moisture covering upper right corner of the sensor?
Best Answer10-08-2017 03:26
10-08-2017 03:26
Contact FitBit support, I just sent my blaze back for the heart rate not working, as the other replies indicate it can be because of moisture.
