07-20-2019
19:42
12:00
07-20-2019
19:42
12:00
Blaze needs to be charged every 2 - 3 hours. Glowing lights on back are on constantly.
07-24-2019 12:03 - edited 03-27-2024 12:06
Welcome to the Community Forums @Linbell! I'm sorry for the late response.
I'd recommend restarting your Blaze and then, let your device to run out of battery to charge it again. Keep an eye on it to see how the battery goes. You can also see: Can I extend my Fitbit device's battery life?
We recommend to charge your trackers via the USB port over a wall adapter. However, it is also possible to charge your Fitbit tracker with a UL certified wall adapter. What may actually cause damage to the tracker's battery (either on a computer or a wall adapter) is the charging time, which if excessive over time may damage the battery and therefore cause quick battery drain or prevent the tracker from charging at all.
Tips to best charge Fitbit trackers are:
For charging purposes, your charging cable can be plugged into any USB power source, including but not limited to:
07-24-2019 13:37
07-24-2019 13:37
07-26-2019 11:03 - edited 01-27-2024 12:55
Hi there @Linbell, thanks for coming back and following the tips and recommendations I've provided.
I've created a support case on your behalf - you should soon receive an email from Customer Support at the email you used to register with the Community forums. If you have any questions, don't hesitate to let me know.
Let me know if you have any questions present.
