Blaze won’t keep a charge
My Blaze won’t keep a charge for more than a few hours. When I put it in the charger, the screen indicates that it’s charging and I can also see when the screen indicates the watch is fully charged. After wearing it for fewer than six hours, it complete dies and shuts off. There’s still just enough battery to let me turn the screen on, but I immediately get the low battery warning on the screen.
126 REPLIES 126
Same thing here. I tried all that and nothing helped.  Also, often when the battery is dead, or very low, I put it on charge and it immediately  shows as full again, which is impossible. If I take it off, it drops again as soon as I start to use it as it obviously isn't fully charged. If I leave it on charge for an hour or two it continues to show fully charged while in the charger, then drops off again after 4-6 hours, totally dead by the end of the day.
There must be more going on for the charging display to be showing as full when it isn't - a software glitch?
I just been offered the standard 25% off a new one. Currently looking at Garmins.
Yep mine does the exact same thing. It is very alarming that all of a sudden so many people as of late have this exact same problem. I too looked at garmins, but worried about their battery life. Best I've seen is the Amazfit Bip.
I am also having the same issue with my Blaze. My trusty device seems to be dying!! I have tried all the suggestions and it is not holding any charge. It is useless to me in this state. Customer service please help!
I am throwing my name and information into this ring.  I bought my Blaze in 2016 and it has been a (mostly) reliable tool.  Then this last week I had to charge my Blaze more often than usual.  I figured "well, its almost 3 years old, so for tech, its had a good run" and chalked it up to its age and a failing battery.  However, upon visiting this forum, it appears that others with newer equipment are having similar problems.  So I am now leaning more towards the "bug" effect.
Like many others here, my blaze (even after a full nights charge) will proceed to show half or little to no battery after only a few hours.  I have attempted the suggested solutions that have been shared here, including a hard reset, turning off all notifications and auto-syncing, and even removing Bluetooth connections so that it is completely isolated from my phone.  All to no significant effects or improvements.  Please tell us there is a solution in the works and that we wont be forced into purchasing new equipment.
I have been looking out on my email and have yet to receive any correspondence from FITBIT.
Hi @mikeyr77@MazzaM97 and @SunsetRunner, it's nice to see new members around. @EvandMsDad@HannahElRe@Billversa and @Tony1970, I'm glad to see you around.
@mikeyr77, I do apologize for missing your previous post and thanks your efforts in trying our suggested steps. @MazzaM97 thanks for letting me know that your device is also having the same behavior. I've contacted our Support Team so they can create a case for you. You'll receive an email from them soon.
@EvandMsDad, thanks for following our team's suggestions. I'd recommend to follow their steps, as well to share details about the outcome, this way they'll be able to provide you with assistance.
@HannahElRe and @Billversa, thanks for taking the time to share your thoughts and I'm sorry to hear about your experience with your Blaze. @SunsetRunner, thanks for letting me know about your device's behavior, as well for trying our suggested steps. I see where are you coming from as the Blaze was designed to motivate you toward your goals. Our team constantly works to improve our products, and be sure that your comments will not be taken for granted.
@SunsetRunner, I've requested a case for you so you can receive further assistance. Keep an eye on your inbox.
@Tony1970, thanks for getting back. I've contacted our Support Team and updated your information so they can reach you out as soon as possible. I appreciate your patience.
See you around!
@LizzyFitbit I am having similar issues with my 18 mo old Blaze. After following all the battery charging recommendations, charging overnight, and the display showing a full charge, the Blaze will show low battery and shut down within hours.
When charging, it starts to charge (red bars) but within a few minutes has gone up to over 50% and within less than an hour is reporting full again - Yet again if I shutdown the blaze and charge it, it carries on charging from a low charge state.
This is a new phenomenon after over a year of daily use.  everyone one this board is familiar with the standard charging protocols, but this seems like an unlikely coincidence.
Any assistance is appreciated!
I’ve tried all of the suggestions but my blaze will not keep a charge. It just started this. I need help. Did you all do an update to kill the battery life to make people upgrade?
Hi @ajoe24 and @Sinergy1. Welcome to our Community Forums.
Thanks for sharing detailed information about your Blaze behavior, as well for checking the the suggestions posted through this thread. While there hasn't been any updated released to damage your device, I see where are you coming from as your devices should be holding charge correctly. I've gone ahead and contacted our Support Team so they can create a case for each of you. You'll receive an email from them shortly.
See you around.
My blaze has begun to have the same charging problems as well. I bought it in Feb 2018. The battery usually would last me 4-5 days, even while receiving all the notifications through the watch. As of 2 weeks ago, the charge has been lasting less and less. Just yesterday, I charged my Blaze all night, used it during a race with notifications turned off, and the Blaze battery was fully dead in the evening. Charged it again for a few hours, wore it to sleep, and the morning I wake up to another dead battery. This is getting really frustrating. I’ve tried all the suggestions on this feed and now I’m reaching out to have a case started as well.
Hi @Audz2835, it's great to see a new member around.
Thanks for sharing your feedback about your experience with your Blaze, and be sure that I'm here to help you. I also appreciate you for trying the suggestions posted through this thread. Because the battery isn't lasting more than a day, I've contacted our Support Team so they can open a case for you. You'll receive a reply from them shortly.
See you around. Robot Happy
How frustrating when you go out on your run and your watch is DEAD... charged all night and yet DEAD within a couple of hours.  How bad is it that we rely on this kind of data to keep us motivated.  Running last night sucked because A. my blaze was dead.  B. no tracking of my run C. how many calories I burned on my run and  I could go on and on with this.... it's frustrating that you break the bank for a watch that promises you and less than a year it's dead.   Who has that kind of money to spend on something like this... WHY??  I have spent just about half the morning reading posts of everyone having this same issue... NO RECALL  tried everything and still DEAD  battery in a short amount of time...
Some one needs to fix this and 25% off the next purchase why would we want that just fix what we already have.
Totally disappointed in this.
I've got a Ticwatch Mobvoi S2 now, the Fitbit is in landfill.
It can't just be a personal issue as so many of us seem to have it, which means it's either an update, or something specific to a bath of them.
Whatever it is I wish everyone good luck, 25% off a device that may give up after a few months is ridiculous, I'm glad I have the watch I have now as it beats any Fitbit product.
I presume this mesaage will indeed be deleted as my previous one was too, if it is it isn't a big loss.
Godspeed y'all
I have reset the device two or three times, left it to charge over night, and changed all settings that would extend battery life but still cannot seem to get more than 5 or 6 hours out of it.
Exactly, everyone is facing the same issue. Coincidence? I think not.
I have just begun having the same issue. This came on suddenly and based on numerous forum topics and comments, there are so many others experiencing the same issue, which also happened suddenly. I believe it must be a technical issue.  I have tried everything you suggested and more. I have no more time to commit to this problem. Please dig further into the issue.
It really has to be something their end, either with an update or a combination of factors, I just don't understand why they can't investigate, keep people informed and if it is their fault rectify is and be honest.
Instead here is 25% another potential shoddy product.
From the posts in this chain alone, this has been an ongoing issue for 6+ weeks and there is still no solution?
Just imagine those that don't use the forums, I bet we are the tip of a Titanic sinking iceberg.
I'm not bothered now for me as I say, I just want to know what went wrong and for everyone else to get it fixed.
Hello my blaze won’t hold
its charge I have reset it etc I charge it over night and it barely last a day can someone help me please
