03-17-2016 20:05
03-17-2016 20:05
05-23-2016 05:48
05-23-2016 05:48
Hello @Beaglelover It's great to see you around. Thanks for sharing your troubleshoot. 🙂 I'm glad to know that your Galaxy S5 and the Blaze are working properly.
Hope to see you around more often! 🙂
It is health that is real wealth and not pieces of silver and gold! Share your story!
Best Answer05-23-2016 10:28
05-23-2016 10:28
Just purcahse a Blaze & adding another device to my IPhone 6. My phone won't stop pairing but the Blaze gave me a green CHECK like it was completed. Time & date is correct.
05-23-2016 10:48
05-23-2016 10:48
It looks as if you have the same problem a lot of iPhone users have. The app has locked up, recommendation would be to kill the Fitbit App and restart.
05-25-2016 15:51
05-25-2016 15:51
I'm having the SAME problem - except my Blase was working for a month or so, then just stopped syncing the other day. So I unpaired it and now I'm having this problem trying to pair it again. Honestly, this Blaze has been nothing but problems since I got it. I will likely go back to my good old Charge HR.
Best Answer05-26-2016 12:10
05-26-2016 12:10
Hello @dholdwick welcome to the FItbit Community! Did you try the suggestion from @Rich_Laue? Is your Blaze working properly now? @spinchik66 if your tracker is not syncing I would suggest to troubleshoot as instructed here.
Let me know if this helps! ![]()
Best Answer06-18-2016 05:17 - edited 06-18-2016 05:20
I'm having the same issues only I have a Samsung Galaxy 6. Everything was fine and then... nothing. I did the forget this device yesterday and attempted to repair the phone and Blaze. Now I get a message that says "Pairing rejected by Blaze".
Best Answer06-18-2016 08:04
06-18-2016 08:04
This may be a longshot but did you try updating your app and software to ensure any bugs are fixed? Otherwise, perhaps trying to uninstall the Fitbit app and reinstall it? Essentially a reboot.
Best Answer06-18-2016 15:06 - edited 06-18-2016 15:07
Beaglelover, Yep... I have done all the things you suggested. I redid everything again this morning and it did synch once, but won't synch again. Pretty frustrating. I need to look at the warranty for Fitbit and Best Buy. It would be nice if I could just exchange it locally. Have owned just a few days short of 90 days.
Best Answer06-18-2016 19:45
06-18-2016 19:45
I believe that Fitbit has a 1 year warranty if Best Buy doesn't take it back. I had issues with my Flex which I got before the Blaze and they gave me a new one as it hadn't been a year. You can email Customer Service about it.
Best Answer06-18-2016 20:37
06-18-2016 20:37
06-20-2016 08:15
06-20-2016 08:15
Hello @Swerdnacm as @Beaglelover mentioned reach out to our support team so they take a look at your tracker's back-end information and provide you a personalized assistance. @Beaglelover and @Rich_Laue thanks for stopping by! 🙂
Catch you later. 😉
Best Answer06-22-2016 10:29
06-22-2016 10:29
Best Answer06-22-2016 10:55
06-22-2016 10:55
Best Answer08-16-2016 03:39
08-16-2016 03:39
hey,
Thanks a ton for the inputs.... Your troubleshoot advise helped me solve my problem.
Regards
08-20-2016 08:00
08-20-2016 08:00
Welcome to the Fitbit Community @Kunalkba and @DianeS1016! @Kunalkba I'm glad to hear you where able to solve your issue! 🙂 @DianeS1016 as @Rich_Laue mentioned the Bluetooth classic is used only for music control. Did you try the troubleshoot he advised for your syncing issues? @Rich_Laue thanks for your cooperation! 😉
Keep me posted! 🙂
Best Answer08-20-2016 10:33
08-20-2016 10:33
Best Answer10-05-2016 05:49
10-05-2016 05:49
I am having the same Issue with my blaze (which I have had for 6 months. All of a sudden this morning it won't connect to my Iphone 6 which it has been all along. I keep getting a message saying make sure myblaze is turned on and in range??????
Best Answer10-06-2016 12:30
10-06-2016 12:30
Hey there @Debtul have you tried restarting the Blaze it shutting it down through the settings? Turned Bluetooth on the phone off/on, or restarted the phone?
Best Answer10-07-2016 08:27
10-07-2016 08:27
Best Answer10-09-2016 03:56
10-09-2016 03:56
Mine does work, with the screen off. It'll sync with the the phone and Fitbit.
