03-17-2016 20:05
03-17-2016 20:05
10-22-2016 16:22
10-22-2016 16:22
11-14-2016 05:05
11-14-2016 05:05
11-14-2016 11:28 - edited 11-14-2016 11:29
@Bikeracer your describing a common limitation of almost any Bluetooth receiver, souch as your tracker. A receiver is only able to connect to one server at a time. If connected to the ipad it won't connect to a second device. This would be the same for a BT headphone or speaker, keyboard, or mouse. OK there is an examption, ive seen BT soeakers with 2 BT channels, you may hook these up to two different devices, but it still is one channel per device.
11-14-2016 16:09
11-14-2016 16:09
11-14-2016 19:47
11-14-2016 19:47
11-15-2016 20:50 - edited 11-15-2016 20:55
I am joining in on this thread and will follow it to see what ends up happening.
My old iPhone 6+ went bad I giot a new one and I am trying to sync the new phone with my existing tracker and it won't see it on bluetooth either 😞
Is there an existing issue in customer service DB? I hve restarted phone and reinstalled app
** I just read some notes in Customer Service and it seems that there is still a "Bluetooth bond" with the old phone. However my old phone has been wiped out and no longer even sees my Blaze. Is this "bond" stored somewhere within my account that I can erase it?
01-09-2017 09:26
01-09-2017 09:26
This recommendation finally worked for me - after trying to find and pair for over an hour, the reinstalling the app and pairing worked - thanks for the info!
01-09-2017 19:04
01-09-2017 19:04
I turned off btle and turned on but not connected please help
01-30-2017 12:18
01-30-2017 12:18
Forgetting the Blaze device in my iPhone Bluetooth settings solve my problem finally able to connect and update my Blaze thanks
02-08-2017 08:19
02-08-2017 08:19
I am having the same problem.
02-08-2017 21:57
02-08-2017 21:57
02-09-2017 00:05
02-09-2017 00:05
@waynehazle about your old phone.
For your Blaze to be bonded,
The phone needs be:
-Within 30 feet
-Turned on
-Bluetooth on
-In the Bluetooth settings the Blaze needs to be a saved device.
If any of the above is false, then the Blaze is not bonded to the old phone.
If the phone atill works, then go into its Bluetooth settings and remove the tracker from there. This is how to permanently unbind a bluetooth device.
03-25-2017 10:54
03-25-2017 10:54
I found out that the set up does work from the computer. Download the Fitbit app to your iphone first. Setup your Fitbit account then do the setup and pairing from the phone not the computer.
03-25-2017 12:51
03-25-2017 12:51
03-25-2017 12:51
03-25-2017 12:51
03-25-2017 18:31
03-25-2017 18:31
Sometimes a restart or a shutdown of the computer is phone is needed.
Please remember you do not and ate unable to pair your tracker to the phone or PC, you need to connect the tracker to your Fitbit account through the Fitbit software/app, then let the Fitbit do the Pairing to the phone /PC
04-06-2017 11:25
04-06-2017 11:25
Unable to pair my iPhone 6plus with my Fitbit Blaze
04-06-2017 13:31 - edited 05-14-2017 19:05
At what step of the setup process does it fail?
Does the app find your Blaze?
Do you get a 4 digit code?
Are you able to add the code to the app?
What happens then?
05-12-2017 15:08
05-12-2017 15:08
On your Fitbit Blaze, go to Settings, Bluetooth Classic, switch that on and then try to pair your phone with the Blaze and the option to pair with Blaze (Classic) should appear and that is the device you choose to pair with.
05-14-2017 19:07
05-14-2017 19:07
The Classic Blaze is only used for controlling music, not syncing.
