12-17-2017
04:47
06:03
AlejandraFitbit
12-17-2017
04:47
06:03
AlejandraFitbit
My Fitbit won't go off the main screen. When I try to scroll left it won't go to any other screen. I can't shut it down since I can't get to the screen. Any advice?
Best Answer12-17-2017 05:54
12-17-2017 05:54
Hi @Busymama162001 - A restart should fix this issue. Please see the help article below.
12-18-2017
06:05
09:37
12-18-2017
06:05
09:37
It's great to see you around @Busymama162001 and @Ozzie65 thanks for stopping by.
I would like to know if you have tried our friend's recommendation? Did the restart procedure work or are you still having issues?
Hope to hear from you soon. ![]()
12-18-2017 08:57 - edited 12-18-2017 08:57
Thanks for the help. I was having this same issue and restarting it worked perfectly. Thanks
12-18-2017 08:59
12-18-2017 08:59
Hi @juliepwine - Glad it worked!
12-18-2017 16:03
12-18-2017 16:03
Hi, I have a similar issue. But mine is turning off alone after showing the initialize display. When I put it to charge it keeps with no reaction and I can hear stranger noises from the charger. I have already reseted my Blaze, but it still with the same issue. Do you know something more could I do? I am worried because I live in Brazil and here it seems not having technical assistance and I'm using this tracker for only 2 months.
Thanks
06:07
09:37
12-20-2017
06:07
09:37
@Lizie, @juliepwine welcome to the Community and @Ozzie65 good to see you here!
@juliepwine I am glad to hear that the procedure provided worked and that your tracker is now working properly. If you need anything else, do not hesitate in posting it.
Now @Lizie, I would like to know if you have contacted our support team, have they offer you a solution for this?
05-29-2019 17:23
05-29-2019 17:23
I have the same issue, my Blaze won't swipe. I tried restarting my phone. Is that what you are talking able when you say restart your device? If you are talking about restarting the Blaze, how do I do that?
Thanks
