06-12-2018
19:14
08:25
AlejandraFitbit
06-12-2018
19:14
08:25
AlejandraFitbit
My Blaze is only about 2 months old, and when I tap on the screen the small numbers will change from calories, steps, stairs etc. info. However, when I try and swipe to select a workout or set an alarm the screen will not move that way. Anyone know how to reset it?
08:25
08:05
06-14-2018
08:25
08:05
It's great to see you around @SunsetRunner and @CptMorgan82 thanks for stopping by.
I would like to know if the instructions provided by our friend here worked? Is your Blaze working properly now?
Hope to hear from you soon. ![]()
Hi!
Yeah this info was really helpful and it's working perfectly again! Thanks for following up
06-15-2018
07:23
08:04
06-15-2018
07:23
08:04
Those are great news @SunsetRunner, I am glad to hear that your Blaze is now working properly. If you need anything else, do not hesitate to post it.
Keep the stepping up! ![]()
I'm having the same problem. Screen seems to be unresponsive to swipes or taps. I've tried resetting the Blaze about 5 times but it still doesn't work.
04:12
07:45
06-17-2018
04:12
07:45
Hey @Ian__P and @spaley16 a warm welcome to the Community.
@spaley16 I am glad to hear that the instructions provided worked and that your Blaze is now working. Let us know if you need further assistance and @Ian__P, since this process didn't work for you, I've gone ahead and escalated your case to our Support Team, for them to take a deeper look at this, please keep an eye on your inbox for further instructions.
Catch you later. ![]()
I’m have the same problem. I’ve tried the reset but that does not work. Any other ideas.
Best AnswerThey couldn't fix mine and as it was out of warranty, didn't replace it. I bought a Garmin instead and have been happy with it
