10-26-2017 23:18
10-26-2017 23:18
I need help!
All of a sudden my blaze battery only lasts a day, it never had notifications or all day syncs on it but I've fiddled around on the app to try and make it more economical but I can't sync it either!
So now I'm stuck with a watch that doesn't tell the right time or date and has to be charged EVERY NIGHT! I've emailed fitbit once and they haven't bothered to reply.
Does anyone have a number I can call to speak to someone about this?
Best Answer10-27-2017 08:47
10-27-2017 08:47
I had the exact same issue. Here's what I tried.
Things required:
Steps
This will help with the battery issue as well as it lowers the number of syncs initiated by the watch in order to sync the settings on to the mobile app.
In any case you should request for a replacement as the problem will reoccur eventually. I had to get mine replaced after suffering with this issue for so long. Customer support were not necesserilly very helpful. So had to send them so many emails. You know the drill 🙂
Hope this helps.
S
PS: Don't forget to
