11-08-2017 14:59
11-08-2017 14:59
Hi, my blaze won’t connect to the phone when I want to use it’s for a run outside. It says keep checking the Fitbit app. I’ve deleted the app, reinstalled, repaired the phone and Fitbit and nothing. Any other suggestions?
thanks!
11-09-2017 06:23
11-09-2017 06:23
A warm welcome to the Forums @Kdancer876.
First of all, I appreciate your efforts in trying to fix this issue. If you are having problem with the GPS connected feature, I recommend taking a look at the My Blaze GPS is not working post and follow the instructions provided there.
I hope this helps, let me know the outcome.
