09-12-2020
16:26
16:15
09-12-2020
16:26
16:15
My Fitbit blaze has been acting up lately..it barely synchronizes data to my phone. Sometimes it does,sometimes it doesn't even when I press sync.
I've tried all troubleshooting procedures.
09-13-2020 02:02
09-13-2020 02:02
Mine won’t sync either
09-13-2020 12:28
09-13-2020 12:28
Neither will mine. It last synched, according to my phone, on 9/10. I did have it set up to auto-sync at some point, but it no longer does. That's fine, but it gives me "tracker not found" error. I switched it to my Kindle to make it a bit easier to see the problem. All other Bluetooth devices are off near me.
09-14-2020 09:25
09-14-2020 09:25
Same here. Just started in the last 3 or 4 days. I have to remove my Blaze from the account (through the app) and then add it again. It will sync once or twice more during the day and then I get the red unable to sync device message when I try to sync. So I have to remove the blaze and add it at least twice a day. Also it has stopped tracking my sleep since all this started. So frustrating.
09-14-2020 10:31
09-14-2020 10:31
It just spontaneously synched and has been working fine enough since. If I didn't just jinx myself. Well, not the sleep tracking, but I'd argue that never worked correctly for me.
Best Answer09-14-2020 17:12
09-14-2020 17:12
Mine is ding the same thing, hasn't synced since 9/10. I uninstalled and reinstalled the app, did not erase any data and still doesn't sync. I just hope Fitbit is better with this problem than it was with my Aria scale.
Best Answer09-15-2020 12:46
09-15-2020 12:46
I have to manual sync mine all the time. That doesn't always work either.
Best Answer09-15-2020 12:58
09-15-2020 12:58
My Blaze has been acting up since 09/01. It sync's randomly. Stopped tracking sleep, all together. Fitbit website has been no help. I think my Blaze support from Fitbit is about the go the way of my Aria support" non existence". Tech support told me that as long as Aria is showing BF and BM I shouldn't have problem🤭. If that's all I wanted why would I bother with an Aria 🤔
Best Answer09-15-2020 19:38
09-15-2020 19:38
Me too. I have to restart when I want to sync.
Best Answer09-19-2020 10:25
09-19-2020 10:25
I have not been able to sinc since 09/14. Have tried pretty much everything and I get the unable to sinc notice.
Best Answer09-20-2020 04:43
09-20-2020 04:43
Same here, only it's been going on for over a month. Even manual synching doesn't always work.
Best Answer09-26-2020 12:36
09-26-2020 12:36
Ditto for me too.
Best Answer09-27-2020 19:01
09-27-2020 19:01
Mine hasn't sinced since 9,08,2020. Manual or auto.
09-28-2020 09:16
09-28-2020 09:16
I have been purchasing Fitbits for years but this will be my last one if they do not fix this!!
09-28-2020 11:46
09-28-2020 11:46
Please call customer service 1-877-623-4997, m-f 8-4pm, i just finished talking to them and found out sync feature cancelled on some devices, etc, when you call have name and model number of device it wont sync to and same info for alternate device, call will take maybe 5 to 15 minutes, depending on whether you need to look up models, such as which ipad etc, they are very patient and when you hang up , your issue should be resolved. Hopefully this helps, i didnt get any of the updated info she told me about. Have a good day.
Best Answer09-28-2020 11:49
09-28-2020 11:49
Hello i called customer service 1-877-623-4997, just got off phone young lady completely resolved my sync problem , 3 months ago ( i didnt get a notice) the sync feature was discontinued for android phones. Long story short i have to use ipad( they check to see if its compatible) and it sync everytime i open the app, please call , you need model of device that won't sync and model number of device you want to sync to. Hope this helps.
Best Answer09-29-2020 11:47
09-29-2020 11:47
I have had this problem on and off since purchasing the Blaze Fitbit. It is a software engineering problem that they are not fixing, cause they want you to purchase another Fitbit. Before you do that, contact the company and ask them to give you a high percentage off to compensate for your troubles. They created a unusable product and they should be to give you something else that does work.
Best Answer09-30-2020 05:09
09-30-2020 05:09
Mine won't sync either. Not even giving me an option to try even though its plugged into the computer using the main website
Best Answer10-02-2020 12:08
10-02-2020 12:08
This is gonna sound stupid but switch to mobile data if you're on wifi, or vice versa......i know how dumb it sounds but it worked for me, i tried to get my fitbit to sync the entire day, i followed all the troubleshooting steps, uninstall the app, reboot (phone and fitbit), unpair, remove device and literally everything else. and then finally i switched it to data and just like that, first try, it synced.
Best Answer10-05-2020 19:47
10-05-2020 19:47
so is mines
