11-27-2018 07:20
11-27-2018 07:20
I just bought the iPhone XR and when Fitbit blaze worked synced for a day with the phone. The next day, it dropped from Bluetooth and won’t sync. It doesn’t even show up in the Bluetooth anymore. I’ve done all the troubleshooting that the website suggests. Any suggestions?
Best Answer11-27-2018 11:55
11-27-2018 11:55
I’m having same issue. Confused
Best Answer11-28-2018 09:30
11-28-2018 09:30
I consistently have problems syncing my blaze with my LG v20. I have notifications turned on and still there are times, ( once a month or so), that the blaze drains the battery and at that point after a charge, it still won't have the correct time, or talk to the phone, I have spent from 9 this morning trying to get the dang thing to sync with the phone so that the time / features even work... I have rebooted the phone, reset the blaze by holding the left and bottom right button till the fitbit logo comes up and still fails to sync. Been about 10 attempts and still won't sync.. The Blaze is already paired with the phone and shows up under bluetooth as a paired device. Turned off bluetooth and restarted it on the phone.. Each time the blaze looses battery this happens and I continue to try to sync until it finally does... Hmm.. is there an updated firmware for the Blaze or something else I can try? I've bought chargers for the car and work and elsewhere so that if I notice a low battery I can charge it before it drains and loses connection....
