Blaze won't turn on after charging
Charged my fit bit blaze and now it won't turn on. Any ideas what happened?
7 REPLIES 7
A warm welcome to the Community @Jacqshut.
I would like to know if you have tried to restart your Blaze? If you haven't, I recommend restarting it by doing the following:
  1. Press and hold the back (left) and bottom buttons until you see the Fitbit logo on the screen. This should take less than 10 seconds.
  2. Let go of the buttons.
After this process, your display should illuminate.
Let me know the outcome. Robot Happy
Thank you. That worked!
After fully charging and placing back into the band it will not turn on.
Tried your suggestion and still nothing. This is a brand new watch.
Those are great news @Jacqshut, I am glad to hear that your tracker is now working properly. If you need anything else, do not hesitate in posting it.
Now @Told, welcome to the Forums and thanks for troubleshooting this by yourself. Since the instructions you tried didn't work, I recommend keeping an eye on your inbox for further instructions.
Catch you later. Robot Happy
Tried the method mentioned previously dbut no joy.
I have tried to restart holding the buttons mentioned but it still will not turn on only see the warning triangle with a thermometer in.
This is from a year ago. I did not send a new request
