08-16-2019
09:01
12:29
08-16-2019
09:01
12:29
This is the second blaze I have owned and have noticed that the battery life do not last. For amount that is spent I'm not seeing the quality of this product. The current blaze I have is not responding after a full charge. I am a loyal Fitbit customer for the last 5 years and was wondering what Fitbit could do to help with this matter. Just seems like I have to buy a new product every 9 months.
Best Answer08-20-2019 12:32 - edited 03-05-2024 03:23
Welcome to the Community Forums @Dcontreras. I'm sorry for the late response. I totally understand how you feel, rest assured that I will do my best to help you.
Our Fitbit Blaze was designed to last 5 days, but the battery life also depends on how frequently you use it’s features. I’ll recommend charging your device with a USB port from a computer or a UL-certified outlet into the wall, then turn OFF all the features that you don’t use and check this help article for more tips and recommendations.
Also, I recommend you to try restarting your device to refresh it’s performance and to see if the screen is back.
