12-25-2016
14:31
21:09
DavideFitbit
12-25-2016
14:31
21:09
DavideFitbit
Hi. Got a Fitbit Blaze for xmas and went to use it and it wouldn't turn on. Managed to sync it while it was plugged in but soon as removed to put back in to start it went off and is unresponsive. Please help!
Best Answer12-25-2016 14:44
12-25-2016 14:44
Did you let it charge all the way? First time takes about 2 hours.
Try a restart. Do it at least 3 times.
Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
If that doesn't help
Contact Support
http://help.fitbit.com/?cu=1
Wendy | CA | Moto G6 Android
12-25-2016 14:44
Restart
Contact Support
Best Answer12-25-2016 14:46
12-25-2016 14:46
Yes had it in charge for about 4 hours. It says battery is full. Also tried to restart several times. Very frustrating and annoying
Best Answer01-24-2017 19:18
01-24-2017 19:18
I need help!i did the reset steps cause my Fitbit won't sync.Has this happened to anyone if so please reply
Best Answer01-25-2017 00:08
01-25-2017 00:08
What reset steps are you refferring to @Please_answer_?
Would you like help in getting your tracker to sync?
