09-30-2018
21:44
04:34
AlejandraFitbit
09-30-2018
21:44
04:34
AlejandraFitbit
Please help!
My Fitbit Blaze was working and fully charged. In a couple minutes, it went completely black, the green light was not on either. I have attempted to put it on the charger, hoping it would do something. That didn't do any good. What would you guys recommend?
04:35
06:23
10-01-2018
04:35
06:23
A warm welcome to the Community @MaryMobary.
I appreciate all the efforts in trying to fix this issue. Have you tried to restart your tracker? If you haven't, I recommend restarting it by doing the following:
Let me know the outcome. ![]()
Best Answer10-01-2018 05:04
10-01-2018 05:04
Good morning,
My Blaze is completely charged but will not turn on I have tried resetting but nothing is happening. Any other suggestions?
Best Answer10-01-2018 17:03
10-01-2018 17:03
Thank you for the reply! I have tried this multiple times. Nothing seems to work. I have had it for almost 2 yrs, so I'm guessing it had a good run. Its probably time to get a new one anyways.
Best Answer10-01-2018 17:06
10-01-2018 17:06
Im in the same situation here... I've tried just about everything. How long have you had it? If its less than a yr, they'll help you replace it. I had mine for almost two, and they cant replace it.... They give you a year warranty:)
Best Answer10-01-2018 17:07
10-01-2018 17:07
Im in the same situation here... I've tried just about everything. How long have you had it? If its less than a yr, they'll help you replace it. I had mine for almost two, and they cant replace it.... They give you a year warranty. 🙂
