10-09-2018
11:03
05:21
AlejandraFitbit
10-09-2018
11:03
05:21
AlejandraFitbit
All of a sudden, the display screen started flickering and data was scrolling wildly across the screen. As of today, the screen is not displaying anything. When plugged in charger, there is no indication of the device charging.
05:22
07:04
10-10-2018
05:22
07:04
Hey @Fola, welcome to the Community.
Thanks for troubleshooting this by yourself. Have you tried to restart your tracker? If you haven't, I recommend restarting it by doing the following:
Let me know the outcome. ![]()
Best AnswerI usually turn my Fitbit Blaze off when I’m commuting to and from work since it is unable to differentiate between me walking/ running/ cycling and my riding a motorcycle. I’ve been doing this for a long time - turning off and turning on the Fitbit Blaze twice a day every day.
Like always I turned it off today evening too, on my way back home. It just will not turn back on now.
1. I have tried charging it.
2. I have cleaned the contact points on the Fitbit Blaze and the charger too.
3. I have tried multiple times to restart/ reset the Fitbit Blaze by pressing the Left button and the Right Lower button for ~10 seconds.
But it just doesn’t turn on. What now?
Best AnswerThis tip just saved me from a meltdown! My blaze ran out of battery today, I put it on charge and... nothing. Wouldn't turn on, no evidence of it charging... I thought it was gone! Then I held the buttons down and it came on, AND it was fully charged!
Thanks!!
10-15-2018
07:50
07:04
10-15-2018
07:50
07:04
Thanks for the update @Fola, @Sunder77 great to see you here and @jonnygrimbo welcome to the Forums.
@Fola, since the instructions provided didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
@jonnygrimbo, I am glad to hear that the instructions worked for you and that your tracker is now working properly, if you need anything else do not hesitate to post it.
@Sunder77, upon checking with our support team, I was told that you have already created a case with them. I know they will be glad to help you out and provide you a solution.
Keep me posted. ![]()
