03-30-2022
23:02
05:25
03-30-2022
23:02
05:25
My Blaze will "charge" but as soon as I take it off, it dies. What do I do to fix it? I've already tried restarting it and didn't work.
Best Answer03-31-2022 11:28
03-31-2022 11:28
Hi @Joseph_Hyrman could be your Blaze is getting old. Mine did the same thing and died. You can always get with support as they "see" things from their end that we can't. Might be able to tell you if it's even really charging.
03-31-2022 18:32
03-31-2022 18:32
Thank you @Odyssey13 I will look into that and see if I can get a new blaze sometime soon. I will update you when I can
03-31-2022 18:56
03-31-2022 18:56
@Joseph_Hyrman the Blaze was discontinued a few years ago. Any Blaze you find, even if it's new in a box, would have a battery that is quite old. I now have the Luxe, which is quite nice. If you want a larger face like the Blaze, look at the Versa or Sense.
03-31-2022 19:32
03-31-2022 19:32
@Odyssey13 I'm looking on Amazon for a more modern one. I just don't know what one is best for keeping track of heart rate, calories, steps, sleep, and water consumption
03-31-2022 20:04
03-31-2022 20:04
You could take the quiz Fitbit has to help us determine the Fitbit that best suits our needs. https://www.fitbit.com/global/us/products/find-your-fit
The Luxe is slim with a soft band and bright screen, but the screen is smaller than the Blaze. It does all those things you mentioned, too.
