12-08-2016 07:15
12-08-2016 07:15
Does blaze connect to Oppo f1 plus...??
Best Answer12-08-2016 13:08
12-08-2016 13:08
Don't know @Erubielandrew dod you check at www.fitbit.com/devices
If not listed there, it does not mean it won't work, just means Fitbit hasn't or is in the process of testing this phone. your experience may vary.
It is posable that the phone has smaller enough hardware to others tyat some if not all the functions might work.
Maybe there is somebody with this model that can give an update.
Best Answer12-09-2016 04:09
12-09-2016 04:09
Welcome to the Community @Erubielandrew and @Rich_Laue thanks for stopping by.
As recommended here by our friend, please check our list of compatible mobile devices. If your phone is not listed there, that's why you are having problems with your tracker connecting with your device. Keep in mind that you can always sync your Fitbit from a computer or compatible phone.
Catch you later. ![]()
Best Answer05-23-2017 16:59
05-23-2017 16:59
Hello any updates on whether the fitbit app and syncing issues are now working on the oppo r9?
Best Answer05-24-2017 04:40
05-24-2017 04:40
Great to see you around @mauricio1971. Regarding to your inquiry, our team is hard working in testing the compatibility of several devices, your patience will be much appreciated. In the meantime, you can keep an eye on our list of compatible mobile devices for any update.
See you later. ![]()
